Shop the Holiday Gift Guide
Framework Desktop Top Panel Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
9
All Time:
137
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Top Panel Removal, Remove the Handle: step 1, image 1 of 3 Framework Desktop Top Panel Removal, Remove the Handle: step 1, image 2 of 3 Framework Desktop Top Panel Removal, Remove the Handle: step 1, image 3 of 3
      • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
      • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
      • Remove the Handle.
      Ask FixBot
    2. Framework Desktop Top Panel Removal, Remove the Top Panel screws: step 2, image 1 of 3 Framework Desktop Top Panel Removal, Remove the Top Panel screws: step 2, image 2 of 3 Framework Desktop Top Panel Removal, Remove the Top Panel screws: step 2, image 3 of 3
      • Use your finger to lift up the two D-rings on the Top Panel screws.
      Ask FixBot
    3. Framework Desktop Top Panel Removal: step 3, image 1 of 3 Framework Desktop Top Panel Removal: step 3, image 2 of 3 Framework Desktop Top Panel Removal: step 3, image 3 of 3
      • Use your fingers to twist the screw counter-clockwise and loosen it.
      • Remove the Top Panel screw.
      Ask FixBot
    4. Framework Desktop Top Panel Removal: step 4, image 1 of 3 Framework Desktop Top Panel Removal: step 4, image 2 of 3 Framework Desktop Top Panel Removal: step 4, image 3 of 3
      • Repeat the same procedure for the other Top Panel screw.
      Ask FixBot
    5. Framework Desktop Top Panel Removal, Remove the Top Panel: step 5, image 1 of 3 Framework Desktop Top Panel Removal, Remove the Top Panel: step 5, image 2 of 3 Framework Desktop Top Panel Removal, Remove the Top Panel: step 5, image 3 of 3
      • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
      • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
      • Lift the Top Panel off the chassis and remove it.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 137
