Up to 20% off select tools
Framework Desktop Secondary Storage Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
3
All Time:
121
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Secondary Storage Installation, Install the SSD: step 1, image 1 of 3 Framework Desktop Secondary Storage Installation, Install the SSD: step 1, image 2 of 3 Framework Desktop Secondary Storage Installation, Install the SSD: step 1, image 3 of 3
      • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • While holding the SSD heat spreader upright, align the SSD's gold contacts with its socket.
      • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
      • Lay the heat spreader back onto the SSD.
      Ask FixBot
    2. Framework Desktop Secondary Storage Installation: step 2, image 1 of 1
      • Use your Framework Desktop Screwdriver to tighten the captive T5 Torx screw securing the SSD.
      Ask FixBot
    3. Framework Desktop Secondary Storage Installation, Reposition the Desktop: step 3, image 1 of 2 Framework Desktop Secondary Storage Installation, Reposition the Desktop: step 3, image 2 of 2
      • Lift the Desktop so it sits upright on your work surface.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
253,071 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 121
