Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
Remove the SSD.
While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
Lift the secondary storage heat spreader out of the Desktop and remove it.
Follow the guide normally, making sure to ignore instructions that involve the secondary storage heat spreader.
