Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Insert the RTC battery connector into its socket and push on the edges until it's fully seated.
Peel the white liner off the back of the RTC battery to expose the adhesive.
Orient the RTC battery so it's aligned with the white circular marking on the Mainboard.
Press the RTC battery onto the Mainboard to secure the adhesive.
Use your Framework Desktop Screwdriver to install the two captive T5 Torx screws securing the RTC battery cover.
