Shop the Holiday Gift Guide
Framework Desktop Primary Storage Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
2
All Time:
121
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Primary Storage Removal, Loosen the SSD screw: step 1, image 1 of 2 Framework Desktop Primary Storage Removal, Loosen the SSD screw: step 1, image 2 of 2
      • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
      • The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
      Ask FixBot
    2. Framework Desktop Primary Storage Removal, Remove the SSD: step 2, image 1 of 3 Framework Desktop Primary Storage Removal, Remove the SSD: step 2, image 2 of 3 Framework Desktop Primary Storage Removal, Remove the SSD: step 2, image 3 of 3
      • While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
      • Remove the SSD.
      Ask FixBot
    3. Framework Desktop Primary Storage Removal, Remove the primary storage heat spreader screw: step 3, image 1 of 3 Framework Desktop Primary Storage Removal, Remove the primary storage heat spreader screw: step 3, image 2 of 3 Framework Desktop Primary Storage Removal, Remove the primary storage heat spreader screw: step 3, image 3 of 3
      • If your replacement SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise skip here.
      • While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
      Ask FixBot
    4. Framework Desktop Primary Storage Removal, Remove the primary storage heat spreader: step 4, image 1 of 1
      • Lift the primary storage heat spreader out of the Desktop and remove it.
      • Follow the guide normally, making sure to ignore instructions that involve the primary storage heat spreader.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,773 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 121
