Shop the Holiday Gift Guide
Framework Desktop Primary Storage Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
4
All Time:
98
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Primary Storage Installation, Loosen the heat spreader screw: step 1, image 1 of 1
      • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
      Ask FixBot
    2. Framework Desktop Primary Storage Installation, Install the SSD: step 2, image 1 of 2 Framework Desktop Primary Storage Installation, Install the SSD: step 2, image 2 of 2
      • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • While holding the heat spreader upright, align the SSD's gold contacts with its socket.
      • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
      Ask FixBot
    3. Framework Desktop Primary Storage Installation, Install the SSD screw: step 3, image 1 of 3 Framework Desktop Primary Storage Installation, Install the SSD screw: step 3, image 2 of 3 Framework Desktop Primary Storage Installation, Install the SSD screw: step 3, image 3 of 3
      • Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard.
      • Tighten the screw securing the SSD.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,773 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 98
