Shop the Holiday Gift Guide
Framework Desktop Power Supply Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
3
All Time:
119
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Power Supply Installation, Place the mounting bracket: step 1, image 1 of 2 Framework Desktop Power Supply Installation, Place the mounting bracket: step 1, image 2 of 2
      • If your power supply doesn't come with its mounting bracket and Power Supply Duct pre-installed, follow the next four steps. Otherwise, skip ahead four steps.
      • Place the mounting bracket on the corner of the power supply closest to the wire bundle.
      Ask FixBot
    2. Framework Desktop Power Supply Installation, Install the mounting bracket screw: step 2, image 1 of 2 Framework Desktop Power Supply Installation, Install the mounting bracket screw: step 2, image 2 of 2
      • Use your Framework Desktop Screwdriver to Install the 5.8 mm‑long Phillips screw securing the mounting bracket.
      Ask FixBot
    3. Framework Desktop Power Supply Installation, Place the Power Supply Duct: step 3, image 1 of 2 Framework Desktop Power Supply Installation, Place the Power Supply Duct: step 3, image 2 of 2
      • Place the Power Supply Duct on the power supply and align its screw holes.
      Ask FixBot
    4. Framework Desktop Power Supply Installation, Install the Power Supply Duct screws: step 4, image 1 of 2 Framework Desktop Power Supply Installation, Install the Power Supply Duct screws: step 4, image 2 of 2
      • Use your Framework Desktop Screwdriver to Install the three 5.8 mm‑long Phillips screws securing the Power Supply Duct.
      Ask FixBot
    5. Framework Desktop Power Supply Installation, Insert the Expansion card cable: step 5, image 1 of 3 Framework Desktop Power Supply Installation, Insert the Expansion card cable: step 5, image 2 of 3 Framework Desktop Power Supply Installation, Insert the Expansion card cable: step 5, image 3 of 3
      • Thread the right Expansion card cable through the gap between the power supply and its duct.
      Ask FixBot
    6. Framework Desktop Power Supply Installation, Place the power supply: step 6, image 1 of 2 Framework Desktop Power Supply Installation, Place the power supply: step 6, image 2 of 2
      • Place the power supply into its slot in the bottom of the Desktop.
      Ask FixBot
    7. Framework Desktop Power Supply Installation, Install the power supply screw: step 7, image 1 of 2 Framework Desktop Power Supply Installation, Install the power supply screw: step 7, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the 4.0 mm‑long Phillips screw securing the power supply.
      Ask FixBot
    8. Framework Desktop Power Supply Installation, Place the rear plate: step 8, image 1 of 2 Framework Desktop Power Supply Installation, Place the rear plate: step 8, image 2 of 2
      • Place the rear plate onto the back of the Desktop.
      Ask FixBot
    9. Framework Desktop Power Supply Installation, Install the rear plate screws: step 9, image 1 of 3 Framework Desktop Power Supply Installation, Install the rear plate screws: step 9, image 2 of 3 Framework Desktop Power Supply Installation, Install the rear plate screws: step 9, image 3 of 3
      • Use your Framework Desktop Screwdriver to install the three 5.9 mm‑long Phillips screws securing the power supply.
      • If you removed the rear plate, install the six 4.0 mm‑long screws securing the rear plate.
      Ask FixBot
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 119
