Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Thread the right Expansion card cable through the gap between the power supply and its duct.
Place the power supply into its slot in the bottom of the Desktop.
Use your Framework Desktop Screwdriver to install the 4.0 mm‑long Phillips screw securing the power supply.
Use your Framework Desktop Screwdriver to install the three 5.9 mm‑long Phillips screws securing the power supply.
If you removed the rear plate, use your Framework Desktop Screwdriver to install the six 4.0 mm‑long screws securing the rear plate.
