Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Insert the Power Button Board cable into the slot in the Desktop.
Grip the cable from the top of the Desktop and thread it through the chassis.
Place the board into its slot in the Desktop so the alignment peg is threaded through its hole in the board.
Use your Framework Desktop Screwdriver to install the two 4.5 mm‑long screws securing the Power Button Board.
Rotate the Desktop onto its right side so the Mainboard is facing upward.
Press the power button cable into its rubber clips in the chassis.
Slide the power button cable over the nine-pronged connector on the Mainboard.
Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
Press the Front Panel flat to the chassis and let it align to the magnets.
