Shop the Holiday Gift Guide
Framework Desktop Mainboard Removal
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
9
All Time:
187
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Mainboard Removal, Disconnect the top Expansion Card cable: step 1, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the top Expansion Card cable: step 1, image 2 of 2
      • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
      Ask FixBot
    2. Framework Desktop Mainboard Removal, Disconnect the main power cable: step 2, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the main power cable: step 2, image 2 of 2
      • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
      Ask FixBot
    3. Framework Desktop Mainboard Removal, Disconnect the CPU power cable: step 3, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the CPU power cable: step 3, image 2 of 2
      • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
      Ask FixBot
    4. Framework Desktop Mainboard Removal, Disconnect the bottom Expansion Card cable: step 4, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the bottom Expansion Card cable: step 4, image 2 of 2
      • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
      Ask FixBot
    5. Framework Desktop Mainboard Removal, Reposition the Desktop: step 5, image 1 of 2 Framework Desktop Mainboard Removal, Reposition the Desktop: step 5, image 2 of 2
      • Lift the Desktop so it stands upright on your work surface.
      Ask FixBot
    6. Framework Desktop Mainboard Removal, Remove the Right Panel: step 6, image 1 of 3 Framework Desktop Mainboard Removal, Remove the Right Panel: step 6, image 2 of 3 Framework Desktop Mainboard Removal, Remove the Right Panel: step 6, image 3 of 3
      • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
      • Remove the Right Panel.
      Ask FixBot
    7. Framework Desktop Mainboard Removal, Remove the top plate screws: step 7, image 1 of 3 Framework Desktop Mainboard Removal, Remove the top plate screws: step 7, image 2 of 3 Framework Desktop Mainboard Removal, Remove the top plate screws: step 7, image 3 of 3
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
      Ask FixBot
    8. Framework Desktop Mainboard Removal, Remove the top plate: step 8, image 1 of 2 Framework Desktop Mainboard Removal, Remove the top plate: step 8, image 2 of 2
      • Lift the top plate off the Desktop and remove it.
      Ask FixBot
    9. Framework Desktop Mainboard Removal, Reposition the Desktop: step 9, image 1 of 2 Framework Desktop Mainboard Removal, Reposition the Desktop: step 9, image 2 of 2
      • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
      Ask FixBot
    10. Framework Desktop Mainboard Removal, Remove the Wi-Fi Module screw: step 10, image 1 of 2 Framework Desktop Mainboard Removal, Remove the Wi-Fi Module screw: step 10, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
      Ask FixBot
    11. Framework Desktop Mainboard Removal, Disconnect the Wi-Fi module: step 11, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the Wi-Fi module: step 11, image 2 of 2
      • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
      Ask FixBot
    12. Framework Desktop Mainboard Removal, Reposition the Wi-Fi module: step 12, image 1 of 3 Framework Desktop Mainboard Removal, Reposition the Wi-Fi module: step 12, image 2 of 3 Framework Desktop Mainboard Removal, Reposition the Wi-Fi module: step 12, image 3 of 3
      • Move the Wi-Fi module towards the center of the Mainboard to keep it out of the way.
      Ask FixBot
    13. Framework Desktop Mainboard Removal, Reposition the Desktop: step 13, image 1 of 3 Framework Desktop Mainboard Removal, Reposition the Desktop: step 13, image 2 of 3 Framework Desktop Mainboard Removal, Reposition the Desktop: step 13, image 3 of 3
      • Rotate the Desktop onto its right side so the Mainboard is facing upward.
      Ask FixBot
    14. Framework Desktop Mainboard Removal, Disconnect the power button: step 14, image 1 of 2 Framework Desktop Mainboard Removal, Disconnect the power button: step 14, image 2 of 2
      • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
      Ask FixBot
    15. Framework Desktop Mainboard Removal, Remove the Mainboard screws: step 15, image 1 of 2 Framework Desktop Mainboard Removal, Remove the Mainboard screws: step 15, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
      Ask FixBot
    16. Framework Desktop Mainboard Removal, Remove the Mainboard: step 16, image 1 of 3 Framework Desktop Mainboard Removal, Remove the Mainboard: step 16, image 2 of 3 Framework Desktop Mainboard Removal, Remove the Mainboard: step 16, image 3 of 3
      • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
      • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
      Ask FixBot
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 187
