Framework Desktop Heatsink Installation (Heatsink)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Heatsink Installation (Heatsink), Remove the liners: step 1, image 1 of 3 Framework Desktop Heatsink Installation (Heatsink), Remove the liners: step 1, image 2 of 3 Framework Desktop Heatsink Installation (Heatsink), Remove the liners: step 1, image 3 of 3
      • Remove the liners covering the thermal pads on your replacement heatsink.
      Ask FixBot
    2. Framework Desktop Heatsink Installation (Heatsink), Place the heatsink: step 2, image 1 of 2 Framework Desktop Heatsink Installation (Heatsink), Place the heatsink: step 2, image 2 of 2
      • Tilt the heatsink down towards the rear of the Desktop and place it into its slot on the Mainboard.
      • Only grab the heatsink by its left and right edges (the edges facing the back I/O ports and the Primary SSD). If you grab the other edges, you risk bending the heatsink fins.
      Ask FixBot
    3. Framework Desktop Heatsink Installation (Heatsink), Tighten the heatsink screws: step 3, image 1 of 2 Framework Desktop Heatsink Installation (Heatsink), Tighten the heatsink screws: step 3, image 2 of 2
      • Use your Framework Desktop Screwdriver to tighten the four captive Phillips screws securing the heatsink in an "X" pattern starting with the top right screw.
      • Only tighten the screws a few turns at a time to evenly compress the APU and thermal pads.
      • In order: top right → bottom left → bottom right → top left
      • Use your Framework Desktop Screwdriver to tighten the captive Phillips screw jutting out under the Primary Storage.
      Ask FixBot
Alex Diaz-Kokaisl
250,162 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 64
