OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Did you lose a screw in your Framework Desktop? Fear not! Follow this guide to replace your missing screws with the Framework Desktop Fastener Kit.
Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
Two large screws labeled "M6 ring screws"
Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
If you need help, contact Framework support.
