Shop the Holiday Gift Guide
Framework Desktop Fan Installation (Normal)
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
4
All Time:
105
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Fan Installation (Normal), Insert the CPU fan: step 1, image 1 of 2 Framework Desktop Fan Installation (Normal), Insert the CPU fan: step 1, image 2 of 2
      • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
      • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
      • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
      • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
      Ask FixBot
    2. Framework Desktop Fan Installation (Normal): step 2, image 1 of 3 Framework Desktop Fan Installation (Normal): step 2, image 2 of 3 Framework Desktop Fan Installation (Normal): step 2, image 3 of 3
      • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
      • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
      Ask FixBot
    3. Framework Desktop Fan Installation (Normal), Insert the fan duct: step 3, image 1 of 2 Framework Desktop Fan Installation (Normal), Insert the fan duct: step 3, image 2 of 2
      • Lay the fan duct on top of the fan with the lip facing upward.
      • Align the screw holes on the fan duct with the ones on the fan.
      Ask FixBot
    4. Framework Desktop Fan Installation (Normal), Install the fan screws: step 4, image 1 of 2 Framework Desktop Fan Installation (Normal), Install the fan screws: step 4, image 2 of 2
      • Remove the fan screws from their packaging and make sure there are four screws total.
      Ask FixBot
    5. Framework Desktop Fan Installation (Normal): step 5, image 1 of 2 Framework Desktop Fan Installation (Normal): step 5, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
      Ask FixBot
    6. Framework Desktop Fan Installation (Normal), Connect the fan: step 6, image 1 of 2 Framework Desktop Fan Installation (Normal), Connect the fan: step 6, image 2 of 2
      • Orient the main fan cable so its two vertical lines are facing you.
      • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
      Ask FixBot
    7. Framework Desktop Fan Installation (Normal), Connect the RGB cable: step 7, image 1 of 3 Framework Desktop Fan Installation (Normal), Connect the RGB cable: step 7, image 2 of 3 Framework Desktop Fan Installation (Normal), Connect the RGB cable: step 7, image 3 of 3
      • If you aren't using an RGB fan, then skip this step.
      • Orient the RGB cable so the arrow is on the right side of the connector.
      • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,773 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 105
