Shop the Holiday Gift Guide
Framework Desktop Antenna Removal
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
14
All Time:
100
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop Antenna Removal, Reroute the power button cable: step 1, image 1 of 3 Framework Desktop Antenna Removal, Reroute the power button cable: step 1, image 2 of 3 Framework Desktop Antenna Removal, Reroute the power button cable: step 1, image 3 of 3
      • Pull the power button cable out of its rubber clips on the chassis.
      Ask FixBot
    2. Framework Desktop Antenna Removal, Reroute the antenna cables: step 2, image 1 of 2 Framework Desktop Antenna Removal, Reroute the antenna cables: step 2, image 2 of 2
      • Push the antenna cables out of the metal hook in the chassis.
      Ask FixBot
    3. Framework Desktop Antenna Removal: step 3, image 1 of 2 Framework Desktop Antenna Removal: step 3, image 2 of 2
      • Pull the black antenna cable out of the plastic clip in the chassis.
      Ask FixBot
    4. Framework Desktop Antenna Removal, Peel off the copper film: step 4, image 1 of 2 Framework Desktop Antenna Removal, Peel off the copper film: step 4, image 2 of 2
      • Use your fingers to peel the left antenna's copper film off the chassis.
      Ask FixBot
    5. Framework Desktop Antenna Removal, Remove the left antenna screws: step 5, image 1 of 2 Framework Desktop Antenna Removal, Remove the left antenna screws: step 5, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the left antenna.
      Ask FixBot
    6. Framework Desktop Antenna Removal, Remove the left antenna: step 6, image 1 of 2 Framework Desktop Antenna Removal, Remove the left antenna: step 6, image 2 of 2
      • Lift the left antenna out of the chassis and remove it.
      Ask FixBot
    7. Framework Desktop Antenna Removal, Peel off the copper film: step 7, image 1 of 2 Framework Desktop Antenna Removal, Peel off the copper film: step 7, image 2 of 2
      • Use your fingers to peel the right antenna's copper film off the chassis.
      Ask FixBot
    8. Framework Desktop Antenna Removal, Remove the right antenna screws: step 8, image 1 of 2 Framework Desktop Antenna Removal, Remove the right antenna screws: step 8, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the right antenna.
      Ask FixBot
    9. Framework Desktop Antenna Removal, Remove the right antenna: step 9, image 1 of 3 Framework Desktop Antenna Removal, Remove the right antenna: step 9, image 2 of 3 Framework Desktop Antenna Removal, Remove the right antenna: step 9, image 3 of 3
      • Lift the right antenna out of the chassis, making sure to thread the cable through the slot.
      • Remove the antenna.
      Ask FixBot
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 100
