Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Place the replacement right antenna into its slot on the chassis, making sure to thread the cable through the slot.
Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the right antenna.
Remove the liner from the back of your replacement right antenna.
Press the right antenna's copper film onto the chassis and adhere it.
Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the left antenna.
Remove the liner from the back of your replacement left antenna.
Press the left antenna's copper film onto the chassis and adhere it.
Press the black antenna cable into the plastic clip in the chassis.
Push the power button cable into its rubber clips on the chassis.
