This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Fixing method: Adhesive
Tear apart the adhesive section by hand
Disassemble it by hand
If it is hard to take it off, you can use a knife cutting into the parting line to help
Fixing method: Screw-fixed
After the last step, the screws appear
5 screws in total
2 kinds of screws
Rotate the screwdriver counterclockwise
Use a knife or a flathead screwdriver to cut into the parting line.
The casing is held together by snaps, so it may require some force to disassemble.
This also uses a snap-fit design. It requires more force to disassemble by hand.
4 screws in total
It is an inclined plane, so just pull it slightly to take it off
Fix method: Snap structure
Peel it off by hand
This is the last disassembly step of the left earpiece. Most of the steps for the right earpiece are the same.
Peel it off slightly by hand
Peel off the rubber part
The screws and the sponge then appear
2 on each side
4 in total
Fixing method: Snap structure
After the last step, turn it over and the metal piece will drop out
8 categories are included
Sponge, Leather, Rubber, Screws, Metal, Plastic, adhesive components, electronic components
Follow the instructions in reverse order for reassembly.
