Fosera Scandle 200 Motherboard Removal
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: step 1, image 1 of 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: step 2, image 1 of 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: step 3, image 1 of 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: step 4, image 1 of 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: step 5, image 1 of 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Vladislav Ignatov
585 Reputation
3 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2014 Member of USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 289
