Flydigi Vader 4 Pro Front Case Replacement
    1. Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 1 of 3 Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 2 of 3 Flydigi Vader 4 Pro Front Case Replacement, Front Case: step 1, image 3 of 3
      • Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
      Ask FixBot
    2. Flydigi Vader 4 Pro Front Case Replacement: step 2, image 1 of 2 Flydigi Vader 4 Pro Front Case Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the rear and front case.
      • Pry around the perimeter of the controller.
      • Remove the rear case and set it to the side of the front case, with care not to strain the connected cable.
      Ask FixBot
    3. Flydigi Vader 4 Pro Front Case Replacement: step 3, image 1 of 1
      • Disconnect the JST-PH connector from its motherboard socket.
      Ask FixBot
Taehwan Kim
636 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 56
All Time: 239
