FlySky FS-TH9X Joystick Replacement
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: step 1, image 1 of 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: step 2, image 1 of 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: step 3, image 1 of 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: step 4, image 1 of 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: step 5, image 1 of 1
  6. FlySky FS-TH9X Joystick Replacement: step 6, image 1 of 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: step 7, image 1 of 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 284
