Shop the Holiday Gift Guide
FlySky FS-TH9X Disassembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
7
All Time:
191
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
To access and fix any damages with the FlySky FS-TH9X remote, the first step to disassemble the remote, is to remove the six screws in the back. Getting access into the internals of the remote. Using this guide you are able to complete your first steps to fixing your remote.
Tools
    1. FlySky FS-TH9X Disassembly, FlySky FS-TH9X Disassembly: step 1, image 1 of 1
      • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
      • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
      Ask FixBot
    2. FlySky FS-TH9X Disassembly: step 2, image 1 of 1
      • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
      Ask FixBot
    3. FlySky FS-TH9X Disassembly: step 3, image 1 of 1
      • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
      Ask FixBot
    4. FlySky FS-TH9X Disassembly: step 4, image 1 of 1
      • Continue to troubleshooting your device.
      Ask FixBot
Author
with
Heath Soucheck
715 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 191
