Fluke 175 Multimeter Fuse Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
94
All Time:
411
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide provides simple, step-by-step instructions for safely replacing the fuses in your Fluke 175 Multimeter. Keep your multimeter functioning accurately with this easy maintenance tip.
    1. Fluke 175 Multimeter Fuse Replacement, Pre-Disassembly: step 1, image 1 of 1
      • Turn off meter and disconnect test leads.
      • Warning: To prevent possible electrical shock, fire, personal injury, or damage to the product:
      • Remove the test leads and any input signals before replacing the fuse.
      • Use ONLY fuses with the amperage, interrupt, voltage, and speed ratings specified.
      • Replace the battery as soon as the low battery indicator appears.
      Ask FixBot
    2. Fluke 175 Multimeter Fuse Replacement, Back Cover Removal: step 2, image 1 of 2 Fluke 175 Multimeter Fuse Replacement, Back Cover Removal: step 2, image 2 of 2
      • Use a Phillips PH1 driver.
      • Remove the 2 bottom screws by turning counterclockwise.
      • Remove the 2 top screws.
      Ask FixBot
    3. Fluke 175 Multimeter Fuse Replacement, Remove Back Panel: step 3, image 1 of 1
      • Carefully remove the front panel from the back section.
      • Do not move control knob while device is open.
      Ask FixBot
    4. Fluke 175 Multimeter Fuse Replacement, Remove Fuses: step 4, image 1 of 2 Fluke 175 Multimeter Fuse Replacement, Remove Fuses: step 4, image 2 of 2
      • Remove and replace fuses.
      • F1 Fuse, 440 mA, 1000 V, FAST
      • F2 Fuse, 11 A, 1000V, FAST
      Ask FixBot
Richard
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 94
All Time: 411
