Fluid Change and Brake Bleeding
    1. Fluid Change and Brake Bleeding, Fluid Change and Brake Bleeding: step 1, image 1 of 2 Fluid Change and Brake Bleeding, Fluid Change and Brake Bleeding: step 1, image 2 of 2
      • Remove the wheel of the calipers you are going to bleed, and remove the brake pads.
      • Install Avid® brake block.
      • You can substitute a 10mm wide block, such as a hex key, if necessary.
      Ask FixBot
    2. Fluid Change and Brake Bleeding, Check the reach adjustment.: step 2, image 1 of 1
      • Levers set for a long reach may have the reservoir closed and will not permit bleeding.
      • Measure from the center of handlebar to the tip of brake lever. The distance should be no more than 80 mm.
      Ask FixBot
    3. Fluid Change and Brake Bleeding: step 3, image 1 of 1
      • If present, set the volume of the caliper system with the adjusting knobs on the lever.
      • On the right-hand lever, turn knob completely counterclockwise, then back clockwise one turn.
      • On the left-hand lever: turn knob completely clockwise, then back counter-clockwise one turn.
      Ask FixBot
      • Rotate the bike and brake levers as necessary to ensure an upward flow from the caliper to the lever bleed screw.
      • Loosen brake lever bolts just enough to allow you to rotate levers to different angles.
      Ask FixBot
      • Install Avid® caliper piston block.
      • This keeps the pistons in position. If pistons were to move, the system would overfill with brake fluid.
      • If no block is available. substitute a 10 mm hex key.
      Ask FixBot
    4. Fluid Change and Brake Bleeding: step 6, image 1 of 1
      • Check to make sure the half-full syringe is free of bubbles and that the tubing clip is closed.
      • At the caliper, remove bleed port screw using a T10 Torx driver.
      • Screw is located in the center of the banjo bolt that attaches the hose to the caliper.
      • Remove port screw and insert the syringe into the fitting.
      Ask FixBot
      • Remove screw front the bleed port near the brake lever.
      • Thread in the quarter-full bleed syringe.
      • This syringe will accept the overflow from the caliper syringe during the bleeding process.
      Ask FixBot
    5. Fluid Change and Brake Bleeding: step 8, image 1 of 2 Fluid Change and Brake Bleeding: step 8, image 2 of 2
      • Open tubing clamp clips on both syringes.
      • Hold the lower syringe to help prevent any air from entering the caliper body.
      • Push the lower syringe plunger to move fluid through the system and out into the lever syringe.
      • Inspect for air bubbles.
      • Inspect for dirty or contaminated fluid
      • Push lower syringe plunger until mostly empty of fluid.
      • Do not fully empty syringe.
      Ask FixBot
      • Close tubing clip on lever syringe.
      • Leave caliper syringe tubing clip open.
      Ask FixBot
    6. Fluid Change and Brake Bleeding: step 10, image 1 of 1
      • Pull brake lever against the handlebar.
      • Secure to the lever to the bar with a toe strap or rubber band.
      Ask FixBot
    7. Fluid Change and Brake Bleeding: step 11, image 1 of 1
      • At lower caliper syringe, push plunger gently to pressurize the system, and then pull back on the plunger.
      • Repeat this process three or four times to pressurize and then apply a vacuum to the caliper.
      • Inspect for any air coming back into syringe.
      • Leave caliper syringe open.
      Ask FixBot
    8. Fluid Change and Brake Bleeding: step 12, image 1 of 1
      • Remove the strap holding lever, but hold it against the bar with your hand.
      • Push caliper syringe plunger and allow the lever to slowly move away from the bar as fluid flows to the caliper.
      Ask FixBot
      • Close the tubing clip at caliper syringe.
      • Unthread caliper syringe and reinstall bleed port screw.
      • Clean off any fluid with alcohol or soapy water.
      Ask FixBot
    9. Fluid Change and Brake Bleeding: step 14, image 1 of 1
      • Open tubing clamp of syringe at lever.
      • Pull back on the plunger to create a vacuum, then push the plunger down.
      • Pull the brake lever slightly and allow it to snap back to help purge any bubbles remaining in lever body.
      • Repeat this process 10 times, or until no more bubbles appear in the tubing.
      Ask FixBot
      • Push the plunger gently as lever syringe is unthreaded from lever.
      • Remove the syringe and install the bleed port screw.
      • Clean up any spilled fluid with alcohol or soapy water.
      Ask FixBot
      • Reinstall brake pads and wheel.
      Ask FixBot
      • Pull the brake lever to bring the pistons to the rotor.
      • Lever should feel firm when pulled with force.
      • Repeat bleed if necessary.
      • Empty the syringes into an appropriate container and store them with their clamps open.
      Ask FixBot
Park Tool
1,211 Reputation
1 Guide authored
Park Tool Member of Park Tool
Community
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 111
All Time: 1,020
