Flash and re-install the firmware of TCA Quadrant
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Quadrant from USB port if you already have it plugged-in.
  1. Flash and re-install the firmware of TCA Quadrant, Press and hold the indicated button: step 4, image 1 of 1
    • Press and hold the button highlighted on the picture.
  2. Flash and re-install the firmware of TCA Quadrant, Connect to PC while holding the button: step 5, image 1 of 1
    • Keep holding the button and connect the Quadrant to USB port of your PC.
    • Once connected, wait a few seconds and let go of the button.
    • You must connect directly to USB port of your PC. It will not work if you connect it to USB port of your Yoke.
    • Your TCA Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Finish Line
Formica Fusca
2,595 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 190
