Fitbit Alta Wristband Replacement
  1. Fitbit Alta Wristband Replacement, Wristband: step 1, image 1 of 1
    • To release a latch, press down on the flat metal button holding the band to the Fitbit. Pull up on the latch to release the band from the body.
  2. Fitbit Alta Wristband Replacement: step 2, image 1 of 1
    • Slide the band up to release it from the Fitbit Alta tracker. Then, repeat on the other side to remove the band.
  3. Fitbit Alta Wristband Replacement: step 3, image 1 of 3 Fitbit Alta Wristband Replacement: step 3, image 2 of 3 Fitbit Alta Wristband Replacement: step 3, image 3 of 3
    • Turn over the Fitbit Alta so the bands are facing upward.
    • Press the latches inward and remove each band by lifting upward.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 11,763
