Bomann DB 774CB Iron
  1. Bomann DB 774CB Iron, Startup: step 1, image 1 of 1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: step 2, image 1 of 3 Bomann DB 774CB Iron, Undressing the handle: step 2, image 2 of 3 Bomann DB 774CB Iron, Undressing the handle: step 2, image 3 of 3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: step 3, image 1 of 2 Bomann DB 774CB Iron, Stripping of the sole: step 3, image 2 of 2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: step 4, image 1 of 1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Putting each screw back in its place is no problem.
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Louis Possoz
435 Reputation
3 Guides authored
Repair Café Louvain-la-Neuve Member of Repair Café Louvain-la-Neuve
Local Repair Groups
2 Members
6 Guides authored
One Comment
Do you instructions in English
Nur Haque - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 56
All Time: 2,972
