Tonneau Trifold Bed Cover Retention Pin Replacement
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: step 1, image 1 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: step 1, image 2 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: step 1, image 3 of 3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: step 2, image 1 of 2 Tonneau Trifold Bed Cover Retention Pin Replacement: step 2, image 2 of 2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: step 3, image 1 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement: step 3, image 2 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement: step 3, image 3 of 3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: step 4, image 1 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement: step 4, image 2 of 3 Tonneau Trifold Bed Cover Retention Pin Replacement: step 4, image 3 of 3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: step 5, image 1 of 2 Tonneau Trifold Bed Cover Retention Pin Replacement: step 5, image 2 of 2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
To reassemble your device, follow these instructions in order.
Christopher King
139 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 705
