Small Engine Recoil Starter Replacement
  1. Small Engine Recoil Starter Replacement, Recoil Starter: step 1, image 1 of 1
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: step 2, image 1 of 1
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: step 3, image 1 of 1
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: step 4, image 1 of 1
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: step 5, image 1 of 1
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: step 6, image 1 of 1
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: step 7, image 1 of 1
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: step 8, image 1 of 1
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
5 other people completed this guide.
James Marmaud
276 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 3,308
