Igloo Mini Fridge IRF32BK Compressor Relay Replacement
  1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: step 1, image 1 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: step 1, image 2 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: step 1, image 3 of 3
    • Clear out all food products in the refrigerator.
    • Unplug the plug from the outlet.
    • Turn the refrigerator backward.
    • Don't turn the mini fridge on its side. Doing so will ruin the mini fridge gas.
  2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 2, image 1 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 2, image 2 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 2, image 3 of 3
    • Use a knife to cut the plastic holding strips.
    • Don't damage the rubber covering. Damaging it can be dangerous when turning the mini fridge back on.
  3. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 3, image 1 of 2 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 3, image 2 of 2
    • Use your thumbs to open the rubber covering.
  4. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 4, image 1 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 4, image 2 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 4, image 3 of 3
    • Use the CR-V screwdriver to unscrew the screw by rotating the screwdriver counter clockwise.
  5. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 5, image 1 of 2 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 5, image 2 of 2
    • Push the flathead screwdriver upward to pry open the metal hinge.
    • Repeat this same step on the other side.
  6. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 6, image 1 of 2 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 6, image 2 of 2
    • Remove the plastic box by pulling it away from the wires.
  7. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 7, image 1 of 1
    • Stick the flathead screwdriver in between the compressor relay and the pot.
    • Wiggle the screwdriver left to right five times.
    • Use your hand to pull the compressor relay from the pot.
  8. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 8, image 1 of 1
    • Use the flathead screwdriver to push the white cable against the compressor relay to disconnect it.
  9. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 9, image 1 of 1
    • Connect the white cable to the new compressor relay.
    • You should hear a click when you connect it correctly.
  10. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 10, image 1 of 2 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 10, image 2 of 2
    • Connect the holes on the compressor relay to the pot.
    • Connect the top hole on the white part of the compressor relay first, then connect the rest of the holes.
  11. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 11, image 1 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 11, image 2 of 3 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 11, image 3 of 3
    • Hold the plastic box as shown in the picture and put it on the compressor relay.
    • Reattach the metal hinge back onto the plastic box.
    • You should hear a click when putting back on the metal hinge.
    • These two steps must be done at the same time in order to work.
  12. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 12, image 1 of 1
    • Reattach the screw to the green wire and use the CR-V screwdriver to reinsert the screw.
    • Refer back to Step 4 to help you complete this step.
  13. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 13, image 1 of 2 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: step 13, image 2 of 2
    • Warp the rubber coating back onto the metal wire.
    • Warp the new plastic holding stripes onto the rubber coating.
Finish Line
4 other people completed this guide.
Rizwan Laghari
217 Reputation
1 Guide authored
3 Comments
Would you happen to know the part numbers for the start relay and overload on this mini fridge that you are working on in this tutorial?
chrisalexandre - Reply
Hi, I have a question?? Does the Igloo irf32bk have a "linear compressor" ?
bruce o - Reply
re-try post! ok,here goes.....does the Igloo IRF32BK operate with a "linear" compressor?
bruce o - Reply
Past 24 Hours: 22
Past 7 Days: 114
Past 30 Days: 413
All Time: 9,163
