Introduction
If you have a bad ram chip or simply want to replace the current ram chip with more ram (a lot of software requires more ram to run smoothly) for the HP ProLiant ML310e Gen8 v2. This is a guide to show you how it’s done. It’s a how to step by step for those who never done this before or unsure how it done. The type of ram that the system use is DDR3 ram (any other ram will not fit). You will need an anti-static wrist-let and a Phillip screwdriver ( in case the tapping screw is too tight to unscrew by hand). Make sure the computer is unplugged from the power before attempting to replace the ram. As always, its best to backup the hard drives before doing any computer works.
Before you begin, make sure the power is unplugged from the computer. Use key to open the front cover, take off the cover and lay it on the side.
Tool used on this step:Anti-Static Wrist Strap$7.95
Attach the anti-static wrist strap. Clip the other end of the anti-static wrist strap to any metal piece on the computer. This will keep the computer from being fried.
2 Comments
My device is not working and I don't know if the problem is with Windows on the hard disk
My device is (proliant ML310e Gen8 v2)
