2005 Jeep Liberty Fog Light Replacement
    1. 2005 Jeep Liberty Fog Light Replacement, Fog Light: step 1, image 1 of 1
      • Open the hood to access the radiator grill tabs.
      • Pull up on the first tab and repeat for the remaining four tabs.
      Ask FixBot
    2. 2005 Jeep Liberty Fog Light Replacement: step 2, image 1 of 1
      • Tilt the radiator grill cover forward and lift up and out to remove.
      Ask FixBot
    3. 2005 Jeep Liberty Fog Light Replacement: step 3, image 1 of 1
      • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
      Ask FixBot
    4. 2005 Jeep Liberty Fog Light Replacement: step 4, image 1 of 1
      • Lift up on the tension screw to release the light housing.
      Ask FixBot
    5. 2005 Jeep Liberty Fog Light Replacement: step 5, image 1 of 1
      • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
      • Repeat the procedure for the right side of the light housing.
      Ask FixBot
    6. 2005 Jeep Liberty Fog Light Replacement: step 6, image 1 of 1
      • Pull the light housing toward you.
      Ask FixBot
    7. 2005 Jeep Liberty Fog Light Replacement: step 7, image 1 of 1
      • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
      Ask FixBot
    8. 2005 Jeep Liberty Fog Light Replacement: step 8, image 1 of 1
      • Remove the light socket from the light housing by turning counter-clockwise.
      Ask FixBot
    9. 2005 Jeep Liberty Fog Light Replacement: step 9, image 1 of 1
      • Remove the light socket from the light housing and replace.
      • The light socket part number is 9145 and can be purchased at any auto parts store.
      • Install the new light socket back into the light housing by turning clockwise.
      • Plug the wiring harness back in the light socket.
      Ask FixBot
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
2 other people completed this guide.
CHARLES CATLEDGE
188 Reputation
1 Guide authored
2 Guide Comments
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - Reply Share
Thank was easy
Sydney Ballard - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 40
All Time: 8,047
