Bracelet Clasp Replacement
  1. Bracelet Clasp Replacement, Bracelet clasp: step 1, image 1 of 1
    • The clasp and metal ring (jump ring) need to be replaced.
    • Replace the jump ring first and then the clasp.
    • The correct size of a jump ring corresponds to the others on the bracelet.
    • Be sure the correct clasp for the bracelet is present.
  2. Bracelet Clasp Replacement: step 2, image 1 of 2 Bracelet Clasp Replacement: step 2, image 2 of 2
    • Use the needle-nose pliers to grasp the jump ring on its side, away from the break in the ring.
  3. Bracelet Clasp Replacement: step 3, image 1 of 2 Bracelet Clasp Replacement: step 3, image 2 of 2
    • Open the jump ring with the needle-nose pliers by holding one side of the ring with the pliers and the other side with your fingers.
    • Another set of needle-nose pliers can be used if the jump ring is too small to grasp.
  4. Bracelet Clasp Replacement: step 4, image 1 of 2 Bracelet Clasp Replacement: step 4, image 2 of 2
    • Attach the new, opened jump ring with the needle-nose pliers.
    • Here, there are two corresponding rings that the jump ring must be inserted through.
  5. Bracelet Clasp Replacement: step 5, image 1 of 1
    • Hold the clasp in one hand and the pliers in the other.
    • Attach the new clasp to the opened jump ring being held by the needle-nose pliers by sliding the jump ring through all corresponding rings, including the clasp.
  6. Bracelet Clasp Replacement: step 6, image 1 of 2 Bracelet Clasp Replacement: step 6, image 2 of 2
    • Use the needle-nose pliers to close the jump ring by squeezing the two arms of the ring together.
    • Be sure to close the jump ring vertically between the two arms of the pliers. The jump ring should be parallel to the arms of the pliers.
  7. Bracelet Clasp Replacement: step 7, image 1 of 1
    • Use the needle-nose pliers to tighten the jump ring, with the jump ring perpendicular to the two arms of the pliers.
  8. Bracelet Clasp Replacement: step 8, image 1 of 2 Bracelet Clasp Replacement: step 8, image 2 of 2
    • Test that the clasp and jump ring are properly attached by holding the bracelet from the clasp and suspending the rest of the bracelet.
    • If the bracelet successfully holds while suspended, the bracelet clasp and jump ring fix is successful.
4 other people completed this guide.
Rachel Gauthier
221 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 43
All Time: 4,615
