Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Fan Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
102
All Time:
1,938
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Fan Replacement
    1. Fan Replacement, Battery: step 1, image 1 of 3 Fan Replacement, Battery: step 1, image 2 of 3 Fan Replacement, Battery: step 1, image 3 of 3
      • Unlock the battery latch on the right.
      • Unlock the battery lock on the left.
      • Remove the battery pack from its slot.
      Ask FixBot
    1. Fan Replacement, Lower Case: step 2, image 1 of 3 Fan Replacement, Lower Case: step 2, image 2 of 3 Fan Replacement, Lower Case: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
      • Check the marks indicating the direction in which the cover must be removed.
      • Remove the bottom cover by removing it in the direction of the markers.
      Ask FixBot
    2. Fan Replacement: step 3, image 1 of 1
      • Then appear the other components of the Laptop.
      Ask FixBot
    1. Fan Replacement, Fan: step 4, image 1 of 3 Fan Replacement, Fan: step 4, image 2 of 3 Fan Replacement, Fan: step 4, image 3 of 3
      • Here is the fan.
      • Disconnect the power cable from this one.
      • Unscrew the screws that hold it in place.
      Ask FixBot
    2. Fan Replacement: step 5, image 1 of 1
      • Gently lift the fan out of its slot.
      Ask FixBot
To reassemble your device follow the following instructions in reverse order
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 102
All Time: 1,938
