Fairphone 1 Midframe Replacement
  1. Fairphone 1 Midframe Replacement, Back Cover: step 1, image 1 of 3 Fairphone 1 Midframe Replacement, Back Cover: step 1, image 2 of 3 Fairphone 1 Midframe Replacement, Back Cover: step 1, image 3 of 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Midframe Replacement: step 2, image 1 of 3 Fairphone 1 Midframe Replacement: step 2, image 2 of 3 Fairphone 1 Midframe Replacement: step 2, image 3 of 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Midframe Replacement, Battery: step 3, image 1 of 3 Fairphone 1 Midframe Replacement, Battery: step 3, image 2 of 3 Fairphone 1 Midframe Replacement, Battery: step 3, image 3 of 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Midframe Replacement: step 4, image 1 of 1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: step 5, image 1 of 3 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: step 5, image 2 of 3 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: step 5, image 3 of 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Midframe Replacement: step 6, image 1 of 2 Fairphone 1 Midframe Replacement: step 6, image 2 of 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Midframe Replacement, Midframe Assembly: step 7, image 1 of 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Midframe Replacement: step 8, image 1 of 3 Fairphone 1 Midframe Replacement: step 8, image 2 of 3 Fairphone 1 Midframe Replacement: step 8, image 3 of 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Midframe Replacement: step 9, image 1 of 2 Fairphone 1 Midframe Replacement: step 9, image 2 of 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Midframe Replacement: step 10, image 1 of 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Midframe Replacement: step 11, image 1 of 3 Fairphone 1 Midframe Replacement: step 11, image 2 of 3 Fairphone 1 Midframe Replacement: step 11, image 3 of 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Midframe Replacement: step 12, image 1 of 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Midframe Replacement, Midframe: step 13, image 1 of 2 Fairphone 1 Midframe Replacement, Midframe: step 13, image 2 of 2
    • The speakerphone speaker is held to the midframe with some mild adhesive.
    • Use the tip of a spudger to pry the speaker off of the midframe.
  14. Fairphone 1 Midframe Replacement: step 14, image 1 of 1
    • Remove the speaker from the midframe.
10 other people completed this guide.
Sam Goldheart
475,657 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,991 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 11,162
