Fairphone 2 Headphone Module Replacement
  1. Fairphone 2 Headphone Module Replacement, Back Cover (one-piece): step 1, image 1 of 2 Fairphone 2 Headphone Module Replacement, Back Cover (one-piece): step 1, image 2 of 2
    • Just peel off the back cover by starting at one of the corners and work your way around.
    • Take off the back cover.
  2. Fairphone 2 Headphone Module Replacement, Battery: step 2, image 1 of 3 Fairphone 2 Headphone Module Replacement, Battery: step 2, image 2 of 3 Fairphone 2 Headphone Module Replacement, Battery: step 2, image 3 of 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  3. Fairphone 2 Headphone Module Replacement, Display Assembly: step 3, image 1 of 3 Fairphone 2 Headphone Module Replacement, Display Assembly: step 3, image 2 of 3 Fairphone 2 Headphone Module Replacement, Display Assembly: step 3, image 3 of 3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  4. Fairphone 2 Headphone Module Replacement: step 5, image 1 of 1
    • Take off the display assembly.
  5. Fairphone 2 Headphone Module Replacement, Headphone Module: step 6, image 1 of 1
    • Remove the two Phillips #0 screws of the headphone module marked by the blue circles.
  6. Fairphone 2 Headphone Module Replacement: step 7, image 1 of 3 Fairphone 2 Headphone Module Replacement: step 7, image 2 of 3 Fairphone 2 Headphone Module Replacement: step 7, image 3 of 3
    • Turn the mainframe around so you're looking at it from the back and can see the two blank parts of the module.
    • Take out the module by first pushing the left part out with your thumb while holding the right side in place.
    • Then push out the right part with your other thumb.
Tobias Isakeit
118,106 Reputation
189 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 26
All Time: 67,402
