Fairphone Wi-Fi Antenna Daughterboard Replacement
  1. Fairphone Wi-Fi Antenna Daughterboard Replacement, Back Cover: step 1, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, Back Cover: step 1, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, Back Cover: step 1, image 3 of 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 2, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 2, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 2, image 3 of 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone Wi-Fi Antenna Daughterboard Replacement, Battery: step 3, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, Battery: step 3, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, Battery: step 3, image 3 of 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 4, image 1 of 1
    • Remove the battery from your Fairphone.
  5. Fairphone Wi-Fi Antenna Daughterboard Replacement, SIM and MicroSD Card: step 5, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, SIM and MicroSD Card: step 5, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement, SIM and MicroSD Card: step 5, image 3 of 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 6, image 1 of 2 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 6, image 2 of 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone Wi-Fi Antenna Daughterboard Replacement, Midframe Assembly: step 7, image 1 of 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 8, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 8, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 8, image 3 of 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 9, image 1 of 2 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 9, image 2 of 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 10, image 1 of 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 11, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 11, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 11, image 3 of 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 12, image 1 of 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone Wi-Fi Antenna Daughterboard Replacement, Wi-Fi Antenna Daughterboard: step 13, image 1 of 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Be careful to pry on the connector, not the socket.
  14. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 14, image 1 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 14, image 2 of 3 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 14, image 3 of 3
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
  15. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 15, image 1 of 1
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Two 2.5 mm Phillips #000 screws
    • One 1.6 mm Phillips #000 screw
  16. Fairphone Wi-Fi Antenna Daughterboard Replacement: step 16, image 1 of 2 Fairphone Wi-Fi Antenna Daughterboard Replacement: step 16, image 2 of 2
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
Andrew Optimus Goldheart
503,806 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 12,052
