Introduction
Prerequisite guide to remove the motherboard. Used for motherboard, camera, and display assembly guides.
Use tweezers to remove the volume rocker and power buttons from the display assembly.
Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
Use tweezers to pull the digitizer cable away from its socket on the motherboard.
Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
