Shop the Holiday Gift Guide
Fairphone 1 Midframe Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
21
All Time:
921
Comments: 7
7 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to remove the plastic midframe from your Fairphone to access internal components.
Tools
    1. Fairphone 1 Midframe Assembly Replacement, Midframe Assembly: step 1, image 1 of 1
      • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Fairphone 1 Midframe Assembly Replacement: step 2, image 1 of 3 Fairphone 1 Midframe Assembly Replacement: step 2, image 2 of 3 Fairphone 1 Midframe Assembly Replacement: step 2, image 3 of 3
      • The midframe is secured to the display assembly by several small plastic clips.
      • Use an opening pick to carefully pry the midframe away from the display assembly.
      • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
      Ask FixBot
    3. Fairphone 1 Midframe Assembly Replacement: step 3, image 1 of 2 Fairphone 1 Midframe Assembly Replacement: step 3, image 2 of 2
      • Carefully round the corner, separating the midframe from the display assembly.
      Ask FixBot
    4. Fairphone 1 Midframe Assembly Replacement: step 4, image 1 of 1
      • After rounding the next corner, the midframe should be free along the bottom and the sides.
      Ask FixBot
    5. Fairphone 1 Midframe Assembly Replacement: step 5, image 1 of 3 Fairphone 1 Midframe Assembly Replacement: step 5, image 2 of 3 Fairphone 1 Midframe Assembly Replacement: step 5, image 3 of 3
      • Run the opening pick and pry along the top seam.
      • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
      Ask FixBot
    6. Fairphone 1 Midframe Assembly Replacement: step 6, image 1 of 1
      • Separate any remaining clips and remove the midframe from the phone.
      Ask FixBot
Author
with
Andrew Optimus Goldheart
516,548 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 921
