Faberware Kitchen Knife Rust Removal/Blade Sharpening
    1. Faberware Kitchen Knife Rust Removal/Blade Sharpening, Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 1, image 1 of 1
      • Materials needed: white vinegar, steel wool or a clean scrub pad, a soft cloth or kitchen towel, baking soda paste (optional) mineral oil (optional).
      • Pour a large quantity of white vinegar into a clean container.
      • a. Large tupperware, bowls or a pot can work, however they should be cleaned before use.
      Ask FixBot
    2. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 2, image 1 of 1
      • Pour a large quantity of white vinegar into a clean container. a. Large tupperware, bowls or a pot can work, however they should be cleaned before use. Place the blade(s) in the vinegar for 10-15 minutes. It is essential to keep the handle out of the vinegar. a. Use a container that you can rest the knife handle so you don’t have to hold it.
      Ask FixBot
    3. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 3, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 3, image 2 of 2
      • After soaking the blade(s) for 10-15 minutes, remove them from the vinegar and use either the steel wool or scrub pad to gently buff out any remaining rust.
      • a. I prefer to use steel wool; however, both work equally effectively.
      Ask FixBot
    4. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 4, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 4, image 2 of 2
      • Rinse the knive(s) with warm water and dry thoroughly.
      Ask FixBot
      • Optional Step: apply a small amount of baking soda paste to the blade. Rinse in warm water and wipe it clean again. This can neutralize acidity and help prevent further rusting.
      Ask FixBot
    5. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 6, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 6, image 2 of 2
      • Wet the sharpener with water and hold the knife(s) at a consistent 20-degree angle. a. If doing multiple knives, sharpen one at a time for safety and best results.
      Ask FixBot
    6. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 7, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 7, image 2 of 2
      • Slide the blades down the sharpener in smooth, controlled strokes. Alternate the side of the blade with each stroke. a. Use an even number of strokes for each side for a consistently sharp blade.
      Ask FixBot
    7. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 8, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 8, image 2 of 2
      • Continue until the edge feels sharp but smooth to touch (use caution when testing). a. An alternative, safer way to test the edge can be with a piece of printer paper. A smooth, even cut will display a sharp, repaired edge.
      Ask FixBot
    8. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 9, image 1 of 2 Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 9, image 2 of 2
      • Wipe clean and add a thin coat of mineral oil to prevent future oxidation.
      Ask FixBot
    9. Faberware Kitchen Knife Rust Removal/Blade Sharpening: step 10, image 1 of 1
      • Store in a dry area.
      Ask FixBot
Safety and Sustainability Considerations:
  1. 1. Always wear a cut resistant glove or maintain a firm grip on the handle when sharpening/scrubbing the blade.
  1. 2. This method uses no hazardous chemicals and uses materials often found in kitchens that are generally inexpensive and environmentally friendly materials.
  1. 3. Restoring knives rather than replacing them reduces waste and extends equipment lifespan.
Expected Outcomes:
• Faberware stainless steel kitchen knives will obtain a polished, rust-free
appearance.
• Efficiency and safety in the kitchen will improve.
• Users can gain increased confidence in their right to repair an essential kitchen tool
and learn a sustainable repair habits.
Attached Documents
Andrew Lynch
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 56
All Time: 157
