FLUKE 376FC True-RMS Clamp Meter Battery Replacement
    1. FLUKE 376FC True-RMS Clamp Meter Battery Replacement, Battery Replacement: step 1, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement, Battery Replacement: step 1, image 2 of 2
      • Make sure the meter is in the Off position
      • Turn the meter over and place it on a surface that won't scratch the display face.
      Ask FixBot
    2. FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 2, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 2, image 2 of 2
      • Using the flat blade screwdriver, rotate the battery locking key from the locked to the unlocked position. Be careful not to use a lot of force as the plastic can be easily damaged by the metal screwdriver.
      • The unlucky will show up on the top by the small arrow in the case.
      Ask FixBot
    3. FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 3, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 3, image 2 of 2
      • Use your finger to pull open the battery compartment cover.
      • Replace your AA batteries.
      • Use the reverse instructions to reassemble your meter.
      Ask FixBot
rickwag
1,906 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 76
All Time: 519
