Shop the Holiday Gift Guide
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
75
All Time:
1,506
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This is a guide to help replace a Circuit Board that is damaged or is not working properly in a Midland X-tra Talk Radio. By replacing the circuit board, you will have a new working Talk Radio. Within the Circuit board, the screen and microphone are attached. However the speaker and antenna can be modified separately when taking apart the Talk Radio. This will allow you to work on it separately. The only special skill you may use for this particular project is unscrewing screws, and cutting 2 wires.
Tools
    1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: step 1, image 1 of 2 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: step 1, image 2 of 2
      • First, apply pressure with your thumb on the top of the battery cover.
      • Next, pull down on the cover until it begins to slide.
      Ask FixBot
    2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: step 2, image 1 of 1
      • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
      Ask FixBot
    1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: step 3, image 1 of 1
      • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
      Ask FixBot
    2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: step 4, image 1 of 1
      • Detach back part of the case by gently lifting up.
      Ask FixBot
    1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: step 5, image 1 of 1
      • Remove the old or broken circuit board from the front case by carefully separating it from the back.
      • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
      Ask FixBot
3 other people completed this guide.
Author
with
James Tucker Dunn
404 Reputation
6 Guides authored
Cal Poly, Team 19-43, Regan Winter 2013 Member of Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 75
All Time: 1,506
