How to replace a Euro Cylinder in a Mortise Lock
  1. How to replace a Euro Cylinder in a Mortise Lock, Measure the cylinder: step 1, image 1 of 1
    • Open the door.
    • Measure the distance from the the forend screw holding the cylinder to the faceplate as shown in the picture.
    • Buy the new cylinder.
    • The maximum overhead you can dimension the new cylinder too large is 2mm. If The cylinder sticks out too much it becomes vulnerable to cracking.
  2. How to replace a Euro Cylinder in a Mortise Lock, Remove the screw: step 2, image 1 of 1
    • Use a PZ2 screwdriver to remove the fixing screw from the side of the lock.
    • Some older locks might use a slotted screw instead.
  3. How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: step 3, image 1 of 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: step 3, image 2 of 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: step 3, image 3 of 3
    • Insert the key and turn it to about 20° to the right (or left) to release the cylinder from the lock insert.
    • If you don’t have the old key or the cylinder doesn’t work anymore you can give this guide a try.
    • Pull out the old cylinder.
To install the new cylinder, follow these instructions in reverse order.
Sebastian
32,145 Reputation
71 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 125
All Time: 1,353
