Eureka EasyClean 71C Motor Replacement
    1. Eureka EasyClean 71C Motor Replacement, Bottom Cover: step 1, image 1 of 1
      • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
      Ask FixBot
    2. Eureka EasyClean 71C Motor Replacement: step 2, image 1 of 1
      • Pry off the Riser Visor using the plastic opening tool.
      Ask FixBot
    3. Eureka EasyClean 71C Motor Replacement: step 3, image 1 of 1
      • Remove the screw cap using the metal spudger.
      • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
      Ask FixBot
    4. Eureka EasyClean 71C Motor Replacement: step 4, image 1 of 2 Eureka EasyClean 71C Motor Replacement: step 4, image 2 of 2
      • Unscrew the 14mm PH2 Phillips head screw.
      • Pull the bottom cover off of the rest of the casing.
      Ask FixBot
    1. Eureka EasyClean 71C Motor Replacement, Casing: step 5, image 1 of 1
      • Pull the power switch all the way up and remove the dust cup.
      Ask FixBot
    2. Eureka EasyClean 71C Motor Replacement: step 6, image 1 of 2 Eureka EasyClean 71C Motor Replacement: step 6, image 2 of 2
      • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
      • Pull the casing apart.
      Ask FixBot
    1. Eureka EasyClean 71C Motor Replacement, Motor: step 7, image 1 of 1
      • Pull out the switch board.
      • Ensure the vacuum is turned off and unplugged before handling any of the electronics.
      Ask FixBot
    2. Eureka EasyClean 71C Motor Replacement: step 8, image 1 of 2 Eureka EasyClean 71C Motor Replacement: step 8, image 2 of 2
      • Desolder the pictured red and black wires.
      • For instructions on how to solder and desolder wires, visit this guide.
      Ask FixBot
Tanner Durnil
631 Reputation
6 Guides authored
IUPUI, Team S6-G4, Baechle Fall 2017 Member of IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 98
All Time: 1,193
