Eureka EasyClean 71C Belt Replacement
  1. Eureka EasyClean 71C Belt Replacement, Bottom Cover: step 1, image 1 of 1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Belt Replacement: step 2, image 1 of 1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Belt Replacement: step 3, image 1 of 1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Belt Replacement: step 4, image 1 of 2 Eureka EasyClean 71C Belt Replacement: step 4, image 2 of 2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Belt Replacement, Belt: step 5, image 1 of 2 Eureka EasyClean 71C Belt Replacement, Belt: step 5, image 2 of 2
    • Pull the roller, motor, and belt out of the casing.
    • Separate the belt from both the roller and the motor.
Tanner Durnil
631 Reputation
6 Guides authored
IUPUI, Team S6-G4, Baechle Fall 2017 Member of IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Members
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,528
