Eureka AirSpeed Bagless Zuum Brush Roll Replacement
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: step 1, image 1 of 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: step 1, image 2 of 2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 3, image 1 of 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 3, image 2 of 2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 4, image 1 of 1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 5, image 1 of 1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: step 6, image 1 of 1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
6 other people completed this guide.
Celina Burchett
1,122 Reputation
8 Guides authored
Clemson, Team 2-2, Benson Fall 2014 Member of Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Members
18 Guides authored
One Comment
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 12,029
