Introduction
The Eton Soulra XL has two woofers that are relatively easy to access and reconnect, should one become disconnected. This guide will provide step-by-step instructions to disassemble, clean, and repair loose connections. You will need to know how to solder; review How To Solder and Desolder Connections if you are unfamiliar with the process.
Gently pull down and out on the front cover; it should come off easily.
Extend the solar panel into the upright position to access the screws on the backside of the device.
At this point, the back panel of the device should lift off easily. Lift it off and set aside.
