Introduction
If the hand crank of the Eton FRX3 isn't working, the dynamo unit may have worn, stripped or ceased gears and will need to be replaced.
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
