Ethernet Port Replacement
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: step 2, image 1 of 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: step 3, image 1 of 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: step 4, image 1 of 3 Ethernet Port Replacement: step 4, image 2 of 3 Ethernet Port Replacement: step 4, image 3 of 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: step 5, image 1 of 3 Ethernet Port Replacement, Ethernet Ports: step 5, image 2 of 3 Ethernet Port Replacement, Ethernet Ports: step 5, image 3 of 3
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: step 6, image 1 of 1
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
6 other people completed this guide.
Denis
584 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
12 Guides authored
One Comment
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 83
All Time: 7,010
