Shop the Holiday Gift Guide
Ethernet Cable Connector Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
23
All Time:
2,709
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
As more devices around us become dependent on an internet connection, we need more reliability and/or speed which can be met with a direct internet connection. Overtime, an Ethernet cable can become broken inside the sleeve and stop working from prolonged use. The value of enabling the everyday person to repair these vital cables would lessen the overall downtime they might face and help retain the majority of the cable by only replacing the broken portion. This would reduce overall waste being sent to landfills.
    1. Ethernet Cable Connector Replacement, Connector: step 1, image 1 of 2 Ethernet Cable Connector Replacement, Connector: step 1, image 2 of 2
      • Use the voltage tester to determine where the break in your cable is.
      Ask FixBot
    2. Ethernet Cable Connector Replacement: step 2, image 1 of 1
      • Use a pair of wire cutters to cut the connector head off the cable, cutting one inch away from the breaking point.
      Ask FixBot
    3. Ethernet Cable Connector Replacement: step 3, image 1 of 2 Ethernet Cable Connector Replacement: step 3, image 2 of 2
      • Insert the cable into the upper portion of the crimper to strip the outer sleeve of the cable.
      • Squeeze the handles and rotate the cable to ensure that the sleeve is cut all around.
      • Remove the crimper and then pull back the sleeving.
      • This will expose eight multicoloured wires.
      Ask FixBot
    4. Ethernet Cable Connector Replacement: step 4, image 1 of 1
      • Pull the four pairs of cables in different directions at the base to make sure they aren't tangled.
      Ask FixBot
    5. Ethernet Cable Connector Replacement: step 5, image 1 of 1
      • Untwist the paired cables and ensure that they are not tangled at the base.
      • Straighten the cables as best as you can and fold them back so all eight are all visible.
      Ask FixBot
    6. Ethernet Cable Connector Replacement: step 6, image 1 of 1
      • Arrange these cables in the order shown in the diagram.
      • This is how the cables will be inserted into the connector.
      Ask FixBot
    7. Ethernet Cable Connector Replacement: step 7, image 1 of 1
      • Use your fingers to squeeze the cables about an inch from the top to keep them in order.
      Ask FixBot
    8. Ethernet Cable Connector Replacement: step 8, image 1 of 2 Ethernet Cable Connector Replacement: step 8, image 2 of 2
      • Insert the cables into wire cutters.
      • Cut all the cables at the end so they are flush together.
      • Keep squeezing on the cables even after the cut to ensure they maintain the correct order.
      Ask FixBot
    9. Ethernet Cable Connector Replacement: step 9, image 1 of 1
      • While squeezing the newly cut cables, push the cables into the connector. The small grooves inside the piece should guide the cables into the back of the connector in the same order.
      • Push the cables inside to ensure that they are all the way to the back of the connector. You may need to apply additional force at this step to ensure they are at the end of the connector.
      Ask FixBot
    10. Ethernet Cable Connector Replacement: step 10, image 1 of 1
      • Push the cables inside all the way with force until it does not move any deeper.
      Ask FixBot
    11. Ethernet Cable Connector Replacement: step 11, image 1 of 3 Ethernet Cable Connector Replacement: step 11, image 2 of 3 Ethernet Cable Connector Replacement: step 11, image 3 of 3
      • Insert the connector with the cable attached into the crimper.
      • Push the cable into the back of the crimper until it cannot go any further.
      • Squeeze the handles of the crimper until you hear a small crunch.
      • This sound means that the teeth of the connector have gone into the cables and a connection is made.
      Ask FixBot
    12. Ethernet Cable Connector Replacement: step 12, image 1 of 2 Ethernet Cable Connector Replacement: step 12, image 2 of 2
      • Look at the base of the connector and ensure you see eight cables with the sleeving around it.
      • You should be able to see all cables which means your connection is complete on that side.
      • Repeat steps 1-12 for the connector on the other side of the cable if needed.
      Ask FixBot
    13. Ethernet Cable Connector Replacement: step 13, image 1 of 1
      • Insert the cable into the main tester unit.
      Ask FixBot
    14. Ethernet Cable Connector Replacement: step 14, image 1 of 1
      • Insert the other end into the secondary tester unit.
      Ask FixBot
    15. Ethernet Cable Connector Replacement: step 15, image 1 of 1
      • On the main tester unit, flip the switch to the ON position.
      Ask FixBot
    16. Ethernet Cable Connector Replacement: step 16, image 1 of 3 Ethernet Cable Connector Replacement: step 16, image 2 of 3 Ethernet Cable Connector Replacement: step 16, image 3 of 3
      • The tester will cycle through all connections 1-8.
      • Ensure that the primary and secondary units are in sync, both showing the LED for the same number at the same time.
      • Verify all connections as one mismatched connection will render the cable non-functional.
      Ask FixBot
The same steps can be used to create an entirely new cable from Cat5/6 cable.
5 other people completed this guide.
Author
with
Karan
328 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 23
All Time: 2,709
