Etekcity Lasergrip 1080 Motherboard Replacement
  1. Etekcity Lasergrip 1080 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Motherboard Replacement: step 2, image 1 of 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Motherboard Replacement: step 3, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement: step 3, image 2 of 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: step 4, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: step 4, image 2 of 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Motherboard Replacement: step 5, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement: step 5, image 2 of 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Motherboard Replacement: step 6, image 1 of 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Motherboard Replacement: step 7, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement: step 7, image 2 of 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Motherboard Replacement: step 8, image 1 of 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: step 9, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: step 9, image 2 of 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Motherboard Replacement, Laser: step 10, image 1 of 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Motherboard Replacement: step 11, image 1 of 1
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
  12. Etekcity Lasergrip 1080 Motherboard Replacement, Sensor: step 12, image 1 of 1
  13. Etekcity Lasergrip 1080 Motherboard Replacement: step 13, image 1 of 1
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
  14. Etekcity Lasergrip 1080 Motherboard Replacement, Battery Connector: step 14, image 1 of 1
  15. Etekcity Lasergrip 1080 Motherboard Replacement: step 15, image 1 of 1
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
  16. Etekcity Lasergrip 1080 Motherboard Replacement, Screen: step 16, image 1 of 1
    • Carefully pull the motherboard out of its slot in the body of the device.
  17. Etekcity Lasergrip 1080 Motherboard Replacement: step 17, image 1 of 2 Etekcity Lasergrip 1080 Motherboard Replacement: step 17, image 2 of 2
    • Unscrew the two 3.4 mm screws on the motherboard.
  18. Etekcity Lasergrip 1080 Motherboard Replacement: step 18, image 1 of 1
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
Patrick Crawford
741 Reputation
6 Guides authored
USF Tampa, Team 5-1, Blackwell Fall 2015 Member of USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 451
