HP Mini 311 RAM Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
102
All Time:
4,375
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you want to increase your computers memory or are having trouble with speed, the RAM is simple to replace in HP Mini 311.
Parts
Tools
    1. HP Mini 311 RAM Replacement, Battery: step 1, image 1 of 3 HP Mini 311 RAM Replacement, Battery: step 1, image 2 of 3 HP Mini 311 RAM Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Ask FixBot
    2. HP Mini 311 RAM Replacement: step 2, image 1 of 2 HP Mini 311 RAM Replacement: step 2, image 2 of 2
      • Slide the battery away from the device to remove.
      Ask FixBot
    1. HP Mini 311 RAM Replacement, Memory Shield: step 3, image 1 of 1
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
      Ask FixBot
    2. HP Mini 311 RAM Replacement: step 4, image 1 of 2 HP Mini 311 RAM Replacement: step 4, image 2 of 2
      • Lift the memory shield up and remove from the laptop.
      Ask FixBot
    1. HP Mini 311 RAM Replacement, RAM: step 5, image 1 of 3 HP Mini 311 RAM Replacement, RAM: step 5, image 2 of 3 HP Mini 311 RAM Replacement, RAM: step 5, image 3 of 3
      • Firmly press on the metal pins located on both sides of the RAM.
      • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
      • Simply grab and remove the RAM from the device.
      Ask FixBot
2 other people completed this guide.
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
72 Guides authored
2 Guide Comments
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Reply Share
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 102
All Time: 4,375
